12-07-2007 11:18 AM
Solved! Go to Solution.
12-07-2007 01:59 PM
Does it appear in other font dialogs, inside CVI? For example, for some control that you edit in the User Interface Editor?
If it does appear elsewhere, then the font is installed correctly. In that case, the problem is probably that the font is not monospaced. The source editor only supports monospaced fonts.
Luis
12-07-2007 03:35 PM
It does not appear in other font dialogs including controls in the User Interface Editor?
The font did indeed install in C:\winnt\Fonts, but it still does not come up as an option in the enviornment font preferences. I am using LabWindows/CVI v. 8.1.1, others that I work with are using older versions (6 & 7) with the font installed the same way and it is selectable as a source window font. Did something change with version 8.1.1?
12-10-2007 12:15 PM
12-10-2007 12:34 PM
Thank you for your help. The script for the Font in Notepad reads as "Symbol" instead of "Western".
However, we have another user using LabWindows/CVI v. 8.1.1 and this font is set as his Source Window Font.
Is there anything I can do to set my Source Window Font to a font with a "Symbol" script?
12-10-2007 05:28 PM - edited 12-10-2007 05:32 PM
12-11-2007 11:00 AM
Changing the registry worked! Thank you.
I did make a mistake in my previous message: the other user is using version 8.1.0. but things still worked out well.
We use MS Linedraw for many applications here and intend to use it in the future. An easier fix for this problem in the future would be appreciated.
Thanks again.
03-29-2012 02:48 PM
I'm comming back to this old thread because I want to use Greek (Math) caracters on the uir but the "Symbol" font available in other windows applications (like NotePad) does not display in the font selector in the user interface editor.
I have taken a look at the registry but couldn't find out how to change it in order to get the symbol font.
Here is a screen shoot of my registry.
Could some one advise me what I have to add?
03-29-2012 03:37 PM
Sorry for this post.
The solution is to choose the right Character set
