I had the same problem some weeks ago. I noticed that mesa.dll is used in
dialog box used for printing panels, in that panel you use Labview style
buttons so mesa.dll is called by the runtine engine (or at least this is my
hypothesis). This happened to me after installation of a pre-release of CVI
6.0, then I deleted the vers. 6.0, installed vers. 5.5 again and created a
distribution kit in which I think it has been put by the CVI the runtime
6.0, all was ok until I used the part of my application with PrintPanel
function, so sincerly I don't know if installing RTE 6.0 and using CVI 5.x
is always safe (unless you install in some way also mesa.dll).
Massimo Massignani
"Chris Matthews" ha scritto nel messaggio
news:506500000005000000F85C0000-1011517314000@exchange.ni.com...
> Strange, unless you wrote the UIR file in 6.0 or are using LabVIEW 6.x
> code as well, there shouldn't be this dependency. Maybe you have the
> 6.0 runtime engine DLLs on your machine somehow.
> Regardless, it won't hurt your older programs to have a newer runtime
> engine. Installing the new 6.0 RTE should still fix the problem.
> Chris
