LabWindows/CVI
CMW500 Reource Conflict
I am using LabWindows to remote-contorl the CMW 500.
When I am turn Multi Evaluation mode to see the result of test.
it keeps displaying "Resource Conflict"
I am not really sure about reasons that I am getting "Resource Conflict"
I do not believe that I put wrong inputs...( or i am calling the extra function by LabWindows to control the CMW 500?)
is there any possiable reason that I made mistake in LabWindows ?
I have to do it manually to solve this problem, why and how?
(1,184 Views)
There are so many instruments out there and so many ways of connecting to them that you cannot really pretend to have any reasoonable answer to this question!
Please add any useful detail about your system,like e.g.
  • Make, type and model of your istrument
  • Version of the CVI IDE you are using
  • Version and origin of the driver you are using to communicate with the instrument, if any
  • Communications channel used (usb, ethernet, GPIB, serial... which one?)
  • Any other useful element you know about your scenario
Is there any external application running in the background that controls the instrument? Or a separate task in your application?
(1,165 Views)
