LabWindows/CVI
CVI 2013 and Avast anti virus
I run in the following issue today.
I copied a project to a new folder and ran it.
Avast poped-up telling that it has to scan the new exe.
The issue is that Avast is poping-up and delays the execution each time I make a change to the project.
This was not the case and is still not the case when I run the oroject from the old folder.
Worse each time I terminate the program I get a error message from CVI.
If I unactivate Avast everything works fine.
My questions are:
Is this issue comming from CVI or from Avast?
Why does it only affect new projects or projects copied to new folders?
(2,518 Views)
I think it is possible that the issue is coming from Avast. Check if you have any updates for Avast and if Avast analyses any specific directory which can interfer with your program.
(2,454 Views)
