LabWindows/CVI
CVI 9.0.0 (348) and russian characters.
When i coding, testing program - all fine, russian symbols is correct. But when i build installer - in process i see: russian symbols becomed squares.
If i install this program in my comp, other comp - squares,squares,squares. But program after install work correctly with squares.
How to check visible russian symbols?
Attached screen.
(3,253 Views)
Hi Sergey_st,
Does the program show up with the correct Russian characters after the install?
Also is the operating system (Windows XP from the screenshot), a full Russian version or an English version?
Chris T.
(3,209 Views)
CVI is english, build installator too don't have russian option.
Program work correctly; installator - no.
Where download CVI 9.0.0 with RUS?
(3,206 Views)
Hi Sergey_st,
We looked into the issue and unfortunately found that you will not be able to show the characters correctly in the installer due to the limited amount of languages that are supported by the installer utility. However, as long as the system locale is correct the program itself will look correct.
Sorry for the inconvenience.
Chris T.
(3,088 Views)
