I am using CVI 2012 Real Time with PXI hardware. I am using TCP/IP communication b/n RT and Host. RT is server and Host is client. In my application, after TCP connection is established between client and server, client will send a command , take for example "GET_DATA" to RT, RT has to respond to that by sending that data.
I am successful in
- Establishing RT-Host TCP communication ( I am able to see that host is reading the welcome message sent by RT).
- Host is sending the command "GET_DATA" to RT.
- RT is receiving the "GET_DATA" command from Host.
In TCP server call back function, in TCP_DATAREADY event, i am using ServerTCPRead() to read data from Host. After reading the data, i am comparing the data with expected command and based on that i will be sending the data using ServerTCPWrite().
RT is reading the command from Host, but it is not writing the data to client. I am not sure whether I can use ServerTCPWrite() in TCP Server call back function.
I also tried using multithreaded concept, but not getting success.
Please suggest any solution for this.
Haari
