LabWindows/CVI
CW 3D Graph fonts
CONTEXT
Using Labwindows/CVI 2017.
Using NI CW 3D Graph 8.0 virtual instrument.
QUESTION
Some C functions of the C3D lib normally allow the user to set the font for the axis, the contours, the cursors, etc, but I do not find out the way to do that.
Lets us take the example of the function CW3DGraphLib_CWContoursSetLabelFont (contoursHandle, NULL, myfont);
The parameter type of 'myfont' is CW3DGraphLibObj_Font which is a synonym of CAObjHandle.
The documentation is not clear at all about this type and I cannot find out any NI CW3D example in which a font is changed...
Could anybody explain how to manage fonts under CW3D ?
For example, how to set the font to "arial narrow" with a size of 8 ?
A simple C-code-piece would be appreciated.
(1,173 Views)
Hello erickringot,
There is not much example on how to use CW 3D Graph in LabWindows/CVI because this type of graph was made for VisualBasic and C++ (so for Object Oriented Programming).
That's why the help does not help you.
A workaround could be to create a DLL Wrapper in C++ that will do all the changes and take the reference to the graph and the settings as parameters.
(1,114 Views)
Well...
Expecting a NI engineer to give an example anyway, as NI did for other facilities of the CW3D lib (see the 3d examples available under CVI Example finder: Surfaces, Axis, Colormap, Contours). I am ready to use translations from C-types to Variant and reversely, exactly like in these examples, I just need a minimal information for that.
(1,102 Views)
