LabWindows/CVI
Call to Ini_New causes Dynamic memory is corrupt error
I am using LabWindows/CVI 8.5.1 to implement a dll which really is just a customization of the teststand dll frontend.dll used to login to Teststand's sequence editor. By the way I am working with TestStand 4.1. Unlike most of posts regarding similar issues, I see that error on the first call to Ini_New. The problem seems to be that I make 2 subsequent calls to different exported functions of my dll, although the variable I write the return value of Ini_New to is defined locally. If I move things around such that I make one call to my dll it works...I don't understand what I am doing wrong. The other thing I see is that after calling Ini_Dispose at the end of my function, the pointer isn't freed, but that will have to be the subject of a different post I guess.
Any ideas? I can't post my code as is but If I have to I can make a generic version of this dll I will, as a last resort.
(3,127 Views)
Accepted by topic author freak
Disregard my previous post, I figured out I was using strcat in several locations without properly allocating memory.
(3,118 Views)
