LabWindows/CVI
Can you improve the speed of my CSV Reader and Writer?
I am glad to see that you have resolved all your issues.
Concerning column number limitation, may be you can do the test in the while condition :
while(*carattere && !error && (stringa_in_corso<numero_stringhe)) ==> it will stop the parsing as soon as the column number is reached
Stef
Labwindows/CVI user since version 4.0
Message 21 of 24
(2,429 Views)
i've done it this way because i had already tried it with the old version and there was this problem:
if i have a special column with CR LF inside and i don't parse it because i've reached the maximum readable column when i will parse the next line i will get an error because i'm reading a "inquote" value
Davide Vittorio G. - TLGB S.R.L.
Italian SW Developer
Message 22 of 24
(2,427 Views)
i've done some correction to handle correctly the inquote column with CR LF inside it. this seem to be the final reader version.
commented there is the old version.
i have done also a column counter, maybe it's useful to allocate the destination string
int leggi_riga_csv_v2(char **lines, int riga_partenza, char *stringa_destinazione[], int numero_stringhe, int formato)
	char delimitatore[2] = {',',';'};
	int stringa_in_corso = 0;
	int index_stringa_in_corso = 0;
	int inquote = 0;
	int i = 0;
	int error = 0;
	char *carattere = NULL;
	for(i = 0; i < numero_stringhe; i++){
		stringa_destinazione[i][0]=0;
	//Point to begining of current line
	carattere = lines[riga_partenza];
	//while(*carattere && !error)
	while(!error)
		switch(*carattere){
			case '\"':
				if(index_stringa_in_corso == 0){
					// se come primo carattere ho una " allora e' una stringa speciale
					inquote = 1;
					//carattere++; //skip quote
					carattere++; //get next character
				else{
					if(inquote){
						//Check for double quote
						carattere++;
						if(*carattere == '\"'){
							if(stringa_in_corso < numero_stringhe){
								stringa_destinazione[stringa_in_corso][index_stringa_in_corso++] = *carattere; //concatenate quote
						else if((*carattere == 0) || (*carattere == '\r') || (*carattere == '\n')){
							//end of quoted string
								stringa_destinazione[stringa_in_corso][index_stringa_in_corso] = 0; //terminate string
							error = 1; //reached end of line
						else if(*carattere == delimitatore[formato]){
							//parse next string
							stringa_in_corso++;
							index_stringa_in_corso=0;
						else{
							error = 1; //Quote string not followed by delimiter or end of string !
						else if((*carattere != 0) && (*carattere != delimitatore[formato])){
						else{
							//parse next string
							stringa_in_corso++;
					else
						error = 1; //Quote inside unquoted string !
			break;
			case ',':
				if(formato == 1){
						stringa_destinazione[stringa_in_corso][index_stringa_in_corso++] = '.'; //replace , by .
				else
					//parse next string
					stringa_in_corso++;
				carattere++;
			break;
			case ';':
				if(formato == 0){
						stringa_destinazione[stringa_in_corso][index_stringa_in_corso++] = ';';
				else
					//parse next string
					stringa_in_corso++;
				carattere++;
			break;
			case '\0': // Terminatore
			case '\r': // CR = 0x0D = 13
			case '\n': // LF = 0x0A = 10
				if(inquote){
					//cariage return or line feed inside quote
					//insert line break and parse next line
						stringa_destinazione[stringa_in_corso][index_stringa_in_corso++] = '\r';
						stringa_destinazione[stringa_in_corso][index_stringa_in_corso++] = '\n';
					carattere = lines[++riga_partenza];
				else{
					//end of line
			break;
			default:
				//copy others characters in destination string
				carattere++;
			break;
	return riga_partenza;
int contacolonne_csv(char **lines, int formato)
	int numero_colonne = {0};
	int index_stringa_in_corso = {0};
	int riga_partenza = {0};
	int inquote = 0;
	int error = 0;
	while(!error)
		switch(*carattere){
			case '\"':
					inquote = 1;
				else{
					if(inquote){
						carattere++;
						if(*carattere == '\"'){ //Check for double quote
							index_stringa_in_corso++;
						else if(*carattere == 0){
							numero_colonne++;
							//parse next string
							numero_colonne++;
						else{
					else
			break;
			case ',':
				if(formato == 1){
					// non fare niente
				else
					//end of string
					//parse next string
					numero_colonne++;
				carattere++;
			break;
			case ';':
				if(formato == 0){
					// non fare niente
				else
					//end of string
					//parse next string
					numero_colonne++;
				carattere++;
			break;
				if(inquote){
					// non fare niente
				else{
					//parse next string
					numero_colonne++;
			break;
			default:
				// non fare niente
				carattere++;
			break;
	return numero_colonne;
Message 23 of 24
(2,408 Views)
Hi holly7787,
The best could be to allocate destination strings when parsing a line.
Each time you encounter a new separator you allocate a new string ... then your function can return allocated strings and the number of columns found.
Next part of your code will process strings and free allocated strings.
This will avoid to walk through the whole twice (to count columns and then parse lines).
Last optimization, line splitting is also not required you can just put the content of all your file in a buffer and pass the buffer pointer and the last character offset to your function.
Something like this :
int leggi_riga_csv_v3(char *buffer, int *offset ...
*carattere will become buffer[*offset]
carattere++ will become offset++
Stef
Message 24 of 24
(2,405 Views)
