LabWindows/CVI
Connecting to a printer through ethernet
I have a printer that I wish to send either a Buffer or file to through an ethernet connection in LabWindows but I am not sure how to accomplish this.
Can anyone point me in the right direction?
Thanks!
(2,571 Views)
Hi mjeddi,
What are your system specifications?
OS:
LabWindows/CVI version:
Printer Make:
Printer Model:
What communication protocol does the printer use?
-Mitchell | NI
(2,540 Views)
Hello Mitchel,
Thanks for your response.
LabWindows/CVI: 2015
Printer Make: CAB
Printer Model: Hermes +4
At the moment we are using RS232 in LabWindows to communicate with the printer, but wish to change to Ethernet protocol.
We are able to use ethernet protocol to communicate with it when we use the printer's own software, but I am unsure on how to establish communication using LabWindows.
Thanks!
(2,538 Views)
Does CAB make a C API or driver for the Hermes +4 Printer?
(2,526 Views)
I'm using this for a cab EOS1: How To: Send Data Directly to a GDI Printer
But I had to convert my EPL2 commands to JScript.
(If the link is failing: it's OpenPrinter() - StartDocPrinter() - StartPagePrinter() - WritePrinter() - ...)
/* Nothing past this point should fail if the code is working as intended */
(2,490 Views)
