LabWindows/CVI
Could be A bug in tab control of CVI8
Tab control is used in my program, there are total 4 tabs(main, setup, cleanup,and report), please see attached, there's a table control in first tab:main tab. On its right-click menu, "Goto Report" callback is used to set active tab to the report tab. I encountered a run-time error duing executing this callback. I appreciate someone could help me out of this trouble. Thanks! Jacky
(2,740 Views)
Since tab pages really are child panels of the panel the tab control is on, each callback for a control on a tab page receives the handle of the tab page itself, not the one of the parent panel. This last handle can be retrieved with
GetPanelAttribute (panelHandle, ATTR_PANEL_PARENT, &parent);
On the parent panel handle you may call your
SetActiveTabPage (parent, PANEL_TAB, 3);
(2,725 Views)
