Did I undertand you right: When using an "external instance of CVI" for debugging Teststand starts CVI, CVI starts then the DLL code , which calls the init-function of the IVI driver which spawns the IVI session and therefore is no alien process in IVIs point of view. But when CVI starts Teststand, which starts then the DLL code then CVI is considered as alien process because it didn't start the DLL.
My example also shows that IVIs procedure to reinitialize fails, if the instrument doesn't understand *IDN?.
