05-29-2013 02:00 PM
hello, this is my problem:
some times when my application is running for a few minuts, when I use the DisplayPanel function , the panel don´t appears at screen.
I capture the return result of the operation, but this is the result:
DISPLAY PANEL STATUS[0]: No error has occurred
but the pannel don´t appears.
An idea of the problem?
thanks
Solved! Go to Solution.
05-30-2013 10:19 AM
There is little to tell about this problems with so few details about it.
Is this a top level or a child panel? Can this panel be hidden below another one? Can you move it to a screen position where cennot be overlapped by other application panels? Is your application running when you find this problem or is it stoppd / hang?
Can you post a small sample that exhibits the problem?
06-26-2013 11:26 AM - edited 06-26-2013 11:30 AM
hello again, sorry for not reply earlier, I've been away ...
This is my normal situation:
// PROGRAMA PRINCIPAL --------------------------------------------
int main (int argc, char *argv[]){
int duplicate,
conectdb;
char buffer[256];
// una sola instancia del programa en ejecución
CheckForDuplicateAppInstance (ACTIVATE_OTHER_INSTANCE, &duplicate);
if(duplicate) return(0);
// PANEL PRINCIPAL
if (InitCVIRTE (0, argv, 0) == 0)
return -1; /* out of memory */
if ((panelPrincipal = LoadPanel (0, "cpm1201.uir", PANEL)) < 0)
return -1;
if ((panelLogs = LoadPanel (0, "cpm1201.uir", LOGPANEL)) < 0)
return -1;
if ((panelProd = LoadPanel (0, "cpm1201.uir", PRODPANEL)) < 0)
return -1;
if ((panLOGIN = LoadPanel (0, "cpm1201.uir", LOGINPANEL)) < 0) // this is a problematic panel >> Hiden by default
return -1;
if ((panLOGIN2 = LoadPanel (0, "cpm1201.uir", LOGINPAN2)) < 0)
return -1;
if ((panADMIN = LoadPanel (0, "cpm1201.uir", ADMINPANEL)) < 0)
return -1;
When an user click on a button, a function launch the panel:
int LanzarPanel (void){
else{
RESULT = DisplayPanel (panLOGIN); // Panel Launcher
The first time, the panel not have a problem, always appears,
Hide the panel with: HidePanel (panLOGIN);
and the result is this:
https://docs.google.com/file/d/0B3Y9vUVa5DCnQk93d1FoZmhxTjA/edit?usp=sharing
The problem is that sudenly the panel don't appears but the retur of RESULT = DisplayPanel (panLOGIN); is DISPLAY PANEL STATUS[0]: No error has occurred
img = https://docs.google.com/file/d/0B3Y9vUVa5DCncDRxcmN3VG9uV28/edit?usp=sharing
thanks for all
pd: The panelLogin2 have the same behavior and never fail !!!!
07-04-2013 07:21 AM
I don't have any idea what may be wrong by looking at your code, but looking at your use of panels, it may be more appropriate to use InstallPopup instead of DisplayPanel.
07-04-2013 07:52 AM
thanks for answering,
for the moment I try to solve the problem with DiscardPanel() instead of HidePanel()
and create it a new panel when I need it.
I hope that working correctly ... I need a few tests more ...
tanks.
