11-28-2005 01:21 PM
Hi Folks!!
Do you have any idea of what can I do, becasue I have checked what you mentioned me an the address is the correct.....
Thanks!!!
11-28-2005 04:53 PM
11-29-2005 05:20 PM
11-29-2005 07:47 PM
11-30-2005 10:53 AM
Thanks! for the advice. It worked perfectly. I could send the Email from the windows CMD with the instructions described by you.
But now this means that I have to open a telnet connection from Lab windows to be able to use the InetSendMail() function or what will be the steps to send the email from CVI?
Victor Salcedo
Regards!!
12-02-2005 09:16 AM
Now that I know that it's working to send an Email Manually from the cmd.exe, Do you have an idea what from CVI is not working? Maybe I will need to generate another thing?
Thanks for your support!!!
Regards!!
12-02-2005 10:18 AM
12-02-2005 12:10 PM
12-19-2005 11:51 AM
Hi!
As you know I have tried to use the Function InetSentMail() without success I don't know why this is failing, I have sent the Email from the CMD using the steps described by Shahina and I used the Outlook Sample to send the Email from CVI and it worked, But I can not have Outlook Installed on the all the Test Computers that we have, I would like to find out how to use the Function InetSentMail().
Is there something else to do in order to be able to have this function working properly?
Thanks for your support.......
02-28-2006 06:15 PM
