LabWindows/CVI
How do I control a ZPL label printer via USB
Can you show me how to install NI-VISA driver to connect USB interface printer, and control
the printer through the command,thanks
Message 11 of 14
(665 Views)
Hi, Daniel
I faced same issue,I installed the printer windows driver, but can't connect printer to NI MAX,thanks
Message 12 of 14
(663 Views)
Daniel
You mean you have transferred USB to RS232 controller to communicate with printer?can
you show me how to connect printer through VISA to USB interface,thanks
Message 13 of 14
(663 Views)
You can not connect to a Windows GDI driver through NI VISA! Windows has captured that device and assigned its installed driver and manages all the printing requests through the Windows GDI or optionally XPS API.
As explained here, sending a "raw" print job to a printer has been getting rather hard under Windows 8 and later. You may try his solution explained on that page or look at the source code and use the mentioned .Net component directly.
Rolf Kalbermatter
My Blog
Message 14 of 14
(637 Views)
