LabWindows/CVI
How do I create a directory within CVI?
Agreed.  I appreciate the information you gave a couple months back.  I used the CreateDirectory and GetFileAttributes both from that library.  My first concern was that using CreateDirectory only returns a BOOL.  In my situation, I need to know if it fails because the directory already exists, or otherwise.  But I was able to use GetFileAttributes to at least see if it exists and is a directory.  So that moved me along.  The MakeDir method has several integer return values - handy for error checking.
Again, thanks for the information you had provided above.
Message 11 of 12
(943 Views)
That is what GetLastError() is for. It's the standard way for handling errors in the Windows SDK world. I suggest to always check the documentation before using a function...
http://msdn.microsoft.com/en-us/library/aa363855(v=vs.85).aspx
Message 12 of 12
(924 Views)
