LabWindows/CVI
How do you create an TDM implicit channel.
How do you create a TDM file with an implicit channel using CVI? What properties do you have to set to get an implicit channel? The "representation" property is read-only, so I cannot set it to implicit_linear. So far I have
status = DDC_AddChannel(channelGroupHandle, DDC_Double, "DateTime", "Linear Time", "s", &channelHandle);
status = DDC_CreateChannelProperty(channelHandle, "implicit_start", DDC_Double, 53431389753.546461);
status = DDC_CreateChannelProperty(channelHandle, "implicit_increment", DDC_Double, intervalSeconds);
status = DDC_CreateChannelProperty(channelHandle, "length", DDC_Int32, nPts);
status = DDC_CreateChannelProperty(channelHandle, "lengthmax", DDC_Int32, nPts);
status = DDC_CreateChannelProperty(channelHandle, "monotony", DDC_String, "increasing");
status = DDC_CreateChannelProperty(channelHandle, "displaytype", DDC_String, "time");
(3,966 Views)
Hi Gaius,
Are you looking to set up channels in CVI and then use them in DIAdem?
Tom D.
Staff Software Engineer
NI
(3,942 Views)
Yes, that is correct. I am programming in the CVI environment. I am using the DIAdem library that is available in CVI. I am using CVI 2015 version.
(3,931 Views)
Hi Gaius,
the CVI-TDM library doesn't allow for creating implicit chaannels.
However, in case you only want to write TDM files, the
TDM Header Writer
may be an alternative.
(3,900 Views)
