Hi Levent,
What version of the e4440a driver are you using? Unfortunately the IVI drivers for this device are not supported. That being said, have you tried looking at the e4440 programming manual? I found a copy of the manual here, and after a quick search found the command MRECEIVE is used to change the measurement mode to Measuring Receiver. I hope this helps.
Ted
Message Edited by Ted H on
11-13-2007 02:31 PM
Ted H
Applications Engineering
