LabWindows/CVI
How to get the run time of codes?
I want to how to get the run time of codes.
For example ,
       for(i = 0; i < 10; i++) a = i;
(2,415 Views)
Are you interested in knowing the execution time of a section of code? Would a simple difference between two Timer () values be enough?
double  t0, exeT;
tini = Timer ();
// Code to test
exeT = Timer () - tini;
If not, can you clarify better your question?
(2,385 Views)
