LabWindows/CVI
How to store data into log file(.doc) using CVI
The purpose is to store the capture data(from my cvi program) and store into the log file (.doc). so at the end of the program run I can retrieve the doc file where the data  store to do my analysing .
Why do this: I wanted to create my program into .exe file that why I need this method or do u have other method to intro?
Any ideal or note or example to share? Pls help
(6,415 Views)
If you are explicitly trying to create a Microsoft Word document, then CVI comes with Word Report instrument that can be used to generate such files. The instrument is located in toolslib\activex\word\wordreport.fp, while a sample program can be found in samples\activex\word\wordrpt.cws.
I suggest you take a look at the example program that illustrates the fundamentals of this instrument, next you can start designing your own application using that instrument.
(6,412 Views)
Thanks for the information. let me go try out.
(6,401 Views)
how it work but when i create my program to distribution and run on other PC, the auto save fail and because it can not find the directory path name: how do i set  a fix pathname example c:\\folder1 so that the file will auto store into the fix pathname when using other PC
(6,328 Views)
