LabWindows/CVI
I want to embed internet explorer in a Labwindows Panel.
I try with an ActiveX control, but I can't figure out which one to select.
(3,711 Views)
Hello
Try using the Microsoft Internet Browser control. Thats the name I have on my machine here. After dropping in the control on the panel, right click and select "Generate ActiveX control driver" to give you the functions with which you can manipulate the control.
Bilal Durrani
NI
Bilal Durrani
NI
(3,711 Views)
The control Bilal pointed you to should work, if you have any other problems there is a nice example which ships with CVI which demonstrates using Internet Explorer in an ActiveX container at
[CVI Directory]\samples\userint\activex\WebBrowser.prj
There is also one on using Internet Explorer through ActiveX outside of a container at
[CVI Directory]\samples\activex\ie\iedemo.prj
Both examples are present in both CVI 6 and 7.
Ryan K.
NI
(3,711 Views)
Thanks. I got it to work.
(3,711 Views)
In the new version of labwindows there isn't the example Webbrowser.prj. Can someone give it to me?
(3,154 Views)
Actually this is not completely true. CVI 2013 still has a WebBrowser sample, you can find it at ...\CVI2013\samples\userint\activex\WebBrowser.cws
(3,149 Views)
 Yes I found it after that I wrote the question. However thanks for the fast reply!
(3,143 Views)
