LabWindows/CVI
Import and Export a MAX Configuration by using Labwindows CVI?
I know it is possible with labview from http://digital.ni.com/public.nsf/allkb/BBB5B94C038267DF8625723E00030559?OpenDocument
Is it possible with CVI or Teststand?
Gokhan
(3,296 Views)
Accepted by topic author gocal
There is  a new driver called NI System Configuration.
With this driver you can configure and change things in MAX.
If you already have it installed, go to Help>>Find Examples>>Hardware Input & Output>>System Configuration.
If you doesn't have install it, you can download it from this link:
http://joule.ni.com/nidu/cds/view/p/id/2613/lang/en
Kobi Kalif
Software Engineer
(3,291 Views)
Kobi,
Thanks for the reply. It works
(3,282 Views)
