LabWindows/CVI
LabWindows/CVI has received an invalid reply to a debugging message.
Hi cholulteca,
Can you post the contents of your ni-rt.ini file found on your RT target? Can you also tell me what version you have of the ni-rt/system/cvi_lvrt.dll file located on the target? You will need to ftp that file to your host machine so you can view the version of it.
Best Regards,
Jonathan N.
Message 11 of 15
(1,870 Views)
Ok, here comes the contents of the ni-rt.ini:
_______________________________________________
[LVRT]
StartupDLLs=c:\ni-rt\system\nidevldp.dll;NiRioRpc.dll;c:\NI-RT\system\cvi_lvrt.dll;serial.dll;NiViSrvr.dll;c:\ni-rt\system\taggerrt.dll;c:\ni-rt\system\mxsemb.dll;c:\ni-rt\system\nipxism.dll;niorbp.dll;
SocketSendBufferSize=65535
SocketRecvBufferSize=65535
EnableCPULoadDisplay=True
LABVIEWRTDir=C:\ni-rt\system
PATH=c:\NI-RT\cvi\;C:\ni-rt\system\;
CDIntervalTicks=55
WebServer.Enabled=FALSE
WebServer.LogEnabled=FALSE
WebServer.MimeTypes=htm;text/html;gif;image/gif;jpeg;image/jpeg;png;image/png;txt;text/plain;html;text/html;jpg;image/jpeg;css;text/css;llb;application/x-labview.llb;vi;application/x-labview-vi
WebServer.RootPath=C:\ni-rt\system\www
WebServer.LogPath=C:\ni-rt\system\www\www.log
WebServer.DirectoryIndex=index.htm
RTTarget.VIPath=C:\ni-rt\startup
RTTarget.IPAccess="+*"
RTEnetRcvMode=2
CVIRealTimePort=3291
RTTarget.ApplicationPath=c:\ni-rt\startup\startup.rtexe
RTTarget.EnableFileSharing=True
RTTarget.TimeZone=NFT-1DFT
server.tcp.access=""+*""
server.tcp.serviceName="Main Application Instance/VI Server"
[STARTUP]
MainExe=/ni-rt/system/emblview.exe
EarlyStartupLibraries=C:\ni-rt\system\lvuste.dll;C:\ni-rt\system\tsengine.dll;C:\ni-rt\system\nisl_emb.dll;
[SECURITY]
RootPassword=passwd%%1574633774153763
[SYSTEMSETTINGS]
Comment=00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Comment_Format=512
Host_Name=STM111PXI
Protect_Reboot=TRUE
[TCP_STACK_CONFIG]
DNS_Address=134.245.1.36
Gateway=134.245.2.100
IP_Address=134.245.69.111
Subnet_Mask=255.255.0.0
___________________________________________________________
The version of the cvi_lvrt.dll ist 8.5.0.274
I hope this helps!
Message 12 of 15
(1,850 Views)
By the way, I just re-installed the LabWindows/CVI Run-Time-Engine for RT 8.5.0, with absolutely no effect, the same error message keeps showing up.
Message 13 of 15
(1,848 Views)
Hi cholulteca,
I would like to go ahead and take this issue offline. I can contact my Web team to provide me with your email address only if you allow me to. Do you give me permission to get your contact information so I can contact you?
Jonathan N.
Message 14 of 15
(1,833 Views)
Of course I give you permission 🙂
I just finished reinstalling the whole software on the RT-target, again with no effect...
Message 15 of 15
(1,830 Views)
