LabWindows/CVI
Labwindows Ini files how do I free the memory created by Ini_GetStringCopy command?
I am using Labwindows\CVI ver 6.0 I am using the Labwindows Ini files instrument. How do I free the memory created by Ini_GetStringCopy command? I think the free() command is not correct because it frees memory allocated by only a few commands not including Ini_GetStringCopy .
(2,927 Views)
As you see in the help for the 'Copy of String' parameter in GetStringCopy function:
"You are responsible for freeing the string by calling the free() function."
Roberto
(2,927 Views)
