LabWindows/CVI
Make analog or digital output square wave go to zero on trigger
I am very new to the NI DAQ system.  I am trying to write a program in LabWindows that will make my output , a square waveform, go to zero when I  read a voltage above a certain limit on one of my other channels.  For my application I need this to happen very quickly, taking no more than a few hundred nanoseconds.  I  had initialy thought to use the puase trigger, but that does not change the output pulse from high to low when the event is triggered.  I looked at using the refference tigger, but again the value stays in the "high" state after the trigger event.  I am using a 6024E.  If someone can point me towards a function or an example of how to accomplish this, I would be very grateful.  From my internet research and tinkering with the example codes I am begining to fear that my 6024E is not well suited for this application.
-Dustin
(4,301 Views)
Can you try generating an event to do this? I know that this would be software time but this may give you the output you are looking for. Where if the event is triggered you write a 0 to output. You may need to change the output when you hit the trigger, instead of just pausing.
Paolo F.
(4,266 Views)
Thanks for replying Paolo.  It still took too long to decrease the output to zero.  I have decided to go a different direction.
Thanks again for your response.
(3,960 Views)
