LabWindows/CVI
NON-FATAL RUN-TIME ERROR: "NiCviJ1939KeyPad.c", line 815, col 40, thread id 0x00001234: Function nctSetProperty: (return value == -1074388560 [0xbff621b0]).
I've been facing this issue once I installed new PXI hardware. The Issue doesnt appear in old hardware. The return value explains that "The feature specified has a design under NI-CAN which cannot be made compatible with NI-XNET CAN hardware.
I have no XNET installed for old hardware.
According to NI, installing "NI-XNET Compatibility Library for NI-CAN" should solve the problem of compatibility.
Am I missing anything or anyone has any idea regarding this issue?
(2,793 Views)
Hi siua,
A few questions:
  • What hardware are you using, both new and old (please indicate which is which)?
  • What programming environment are you using and what version?
  • What particular function is throwing the error and for what hardware?
Also, please make sure the NI-XNET Compatibility Library is installed.  This KnowledgeBase article also explains the compatibility capabilities.
Matt S.
Industrial Communications Product Support Engineer
(2,770 Views)
