Need help creating a customized control in a function panel that will display DIO Line Selection information.
I have manage to create the dll code below that gets called by a function panel string control I want to use to choose a DAQ channels such as "Dev3/port9/line2".... The NIDAQmx_NewPhysChanDOLineCtrl () function worked great in a GUI run under an executable. But does not change the control in to a Line Selection Control and then returns an error " The attribute passed is invalid". When called via customized control that points to the dll containing the SelectLines() function shown below.
int DLLEXPORT CVICALLBACK SelectLines (FPCustomInfo *info)
int panel;
int cancelled;
char buf[64] ="";
panel = LoadPanelEx (0, "c:\\Beckwith\\M-7679 Final - 2012\\LabWindowsCVI\\DIO\\lines.uir", PANEL, __CVIUserHInst);
if (panel < 0) return 0;
CenterDialog (info, panel);
InstallPopup (panel);
NIDAQmx_NewPhysChanDOLineCtrl (panel, PANEL_STRING, 0); // Turns Panel String Control into a Line Selection Control
cancelled = RunUserInterface ();
if (!cancelled) // return of 0 "OK"
GetCtrlVal (panel, PANEL_STRING, buf);
FPCustom_SetParamValue (info, 0, buf);
DiscardPanel (panel);
return 0;
