LabWindows/CVI
PXI4464 - Frequency measurement
Hi guys.
Do you know if it is possible to measure frequency using the PXI4464 module? If so, should I do this with the DAQmx library?
I have been trying using the function DAQmxCreateAIFreqVoltageChan and DAQmxReadCtrFreq, but it does not work.
Do you have any ideas?
Regards.
(2,485 Views)
Hey there,
I have tried making an analog frequency task and a counter input frequency task with the PXI 4464 and it is not supported. Since this is a DSA/Sound and Vibration device, it doesn't have counters on the card itself.
Hope this helps.
Aulia V.
(2,431 Views)
