LabWindows/CVI
Plotting a text in the middle of a polygon
Hi
I have a polygon and a text field on a graph.
I would like to center the text field in the polygon. Therefore I should have the size of the bounding rectangle of the text.
I couldn't find an attribute giving this information.
Has someone an idea how I could achieve my goal?
Thank you
(2,319 Views)
A quick and dirty solution: use a (hidden) text message control with the same font and size you are using on the graph and operate based on the bounding rect of that control.
(2,295 Views)
Accepted by topic author Bertrand_ENAC
Hi
Maybe the function GetTextDisplaySize() works for you.
Jan
(2,284 Views)
Thank you. Your answer was helpfull.
(2,192 Views)
