LabWindows/CVI
Problem facing when change the scaling of graph control
I am drawing two plots, one is with respect to left Y axis and anothor one is with respect to right Y axis. I am able to draw the plots as per my requirement. But when I changed the scaling of left Y axis, it applies to both plots.  I think it is because of LEFT Y-axis is active that time. But logically it should not happen. For me only option is redraw plots once scaling is changed. I just wanted to know is this bug in CVI or it is like this only.
Gajanan
(2,723 Views)
Gajanan,
if you set the active y-axis BEFORE plotting the diagram, the plot should not be changed resizing the other axis. Look at the sample project attached: press "Plot" button to draw something on the screen and the "Change right" button setting axis to 0 ÷ 1000: the plot related to left y-axis remains unchanged.
(2,719 Views)
Hi Roberto,
Now I got it.
Gajanan
(2,709 Views)
