05-30-2008 02:23 AM
05-30-2008 09:19 AM
03-20-2013 10:53 AM
I have actually the same problem, that I generate a source code file during custom build steps with script. The file is not open in the editor in order to avoid the refresh message of the editor. My file is then included in another c source code file.
Unfortunately I have the same problem, that I need two compiler runs, in the first one the changes in my generated file are not detected and compiled.
Has there been a change on the CVI environment since I am using the actual 2012 SP1 version ? Or any other suggestions ?
