LabWindows/CVI
Rich Text Box Not Visible When Exporting Panel As a PNG
Hello all,
Whenever I print or save (as an image) a panel with a rich-text box control, made using the ActiveX controls, the rich-text box fails to appear in the output. I can see the box just fine when my program is running, but for some odd reason it will not appear when I try to save or print. The control is not being hidden, or anything like that, before printing. I was able to successfully make the box print and save using my dev computer, however my dev laptop and at home personal PC (running the CVI run-time engine) fail to do so. Any ideas on what is making this strange behaviour occur? Thanks a lot.
CVI 8.5 RTE
PCs w/ Windows XP SP2
(3,582 Views)
Nevermind, I solved my problem. Smiley Tongue I updated RICHTX32.OCX file in the system32 directory and now everything works fine! Thanks anyway.
(3,567 Views)
I had the same problem.  So if anyone's looking for an updated version of richtx32.ocx, go here: http://activex.microsoft.com/controls/vb6/richtx32.cab
(3,323 Views)
