LabWindows/CVI
SetTableCellRangeVals - How do I declare Array of Arrays to pass in Strings
I'm using the SetTableCellRangeVals function.  I have a structure containing strings.  I'm populating an array of strings (array of array of characters) to get the strings from the structure into an array to use in SetTableCellRangeVals.  I have declared the array char strings[NumStr][StrLength].  I can populate this array in a for loop.
When I call SetTableCellRangeVals with "strings" as my parameter, I get  "found 'pointer to array 32 of char', expected 'pointer to pointer to char'.
When I call SetTableCellRangeVals with "*strings" as my parameter, I get  "found 'pointer to char', expected 'pointer to pointer to char'.
When I call SetTableCellRangeVals with "strings[0]" as my parameter, I get  "found 'pointer to char', expected 'pointer to pointer to char'.
How do I declare "strings" if I want to populate it in the for loop and use it in SetTableCellRangeVals?
(Windows 7 CVI 2010 SP1)
(3,743 Views)
take a look at LuisG answer here.
(3,738 Views)
If it helps anyone else, the part I didn't understand was that I needed an array of strings to hold the strings and an array of addresses to hold the address of each string within the array of strings.  Thanks.
(3,730 Views)
Hi, Hawkk.  Can you please post your code that uses the SetTableCellRangeVals() function and the declaration of the arrays that are passed to it?
(3,258 Views)
Sorry I looked but no longer have that SW.
(3,255 Views)
