LabWindows/CVI
Suspicious BUILD LOG message
When I build my application I get the following message in the BUILD LOG:
"The source directory for "T Process" is invalid because it is at the same location as the deployment destination directory (source = "C:\TProcess\cvidistkit.T Process\Volume\", destination = "c:\TProcess\cvidistkit.T Process\")".
It does not seem to affect the build, and the build reports that it has comppleted successfully. What causes this message to appear, and what can be done about it, if anything ??
~Harald.
(4,825 Views)
Hi Harald,
Do you get this message every time you build the application?
If you build it to a different directory, does this change the message?
Rachel M.
(4,800 Views)
I tried your suggestion. The suspicious message does NOT appear when I change the output directory to something other that what I have been using. The strange thing is that even if I delete my normal output directory and then re-create it as a blank directory, the message still appears. That's a head-scratcher !! Any ideas ?? The issue does not seem to affect the build, it's just strange. Thanks,  Harald.
(4,780 Views)
Hi Harald,
Could you post your CVI distribution file? It might be good to take a look at the paths you are using.
Rachel M.
(4,745 Views)
Hello Rachel,
I have attached the "cds" file, as you suggested.
--->>> Thanks for your help !!
~Harald.
P.S. I had to change the ".cds" extension to ".txt", so that it would allow me to attach it to this replay.
(4,730 Views)
