LabWindows/CVI
create ivi driver installer
I am using the "Create IVI Driver Installer" wizard in CVI 8.5 for my IVI driver. I want to add a bunch of examples but don't see a way to add folders(directories) under the <IVI defaut dir>\Drivers\<driver name>. I can add files to this root dir but I want to create folders under here to install the exmples.
Anyone done this?
(3,223 Views)
You can try creating an example folder under this directory, Add file from the example folder then you will be prompted to select the target directory <IVI defaut dir>\Drivers\<driver name>, but it will include the example folder as part of the path
(3,196 Views)
That's how you would think it works but it doesn't. It puts everything that should be under examples in the IVI\Drivers folder.
(3,184 Views)
