LabWindows/CVI
graphcursors.fp not found after installation and library options setup in Meas.Studio 6.
After setting up Measurement Studio 6.0 and browsing for function panels of the instrument libraries in the toolslib\custctrl directory, I found the graphcursors.fp After installation and restart, the related library file is reprotedly missing from the system, and LabWin can not load it.
What is happening?Where can I find the library file?
By the way, during setup, when out of curiosity I asked the installer to to setup the visual C++ components, it reported that I have Visual C++ open and active, and refused to proceed with insgtallation. In fact, I newer installed Visual C++ on my system, it is a clean and fresh setup,with "virgin" HD.
Thanks in advance.
Lajos
(2,610 Views)
Lajos,
You'll need to create an .obj file for that driver. Just open graphcursors.c in a source window and then select Options>>Create Object File. After you do that, the next time CVI starts up it shouldn't complain.
Luis Gomes
NI
(2,610 Views)
