LabWindows/CVI
how to automate NIReports Install
The help for NIReports says that the end user must have the NIReports ActiveX Automation Server installed on their machine for NI Reports to work. How do I automate the installation of that along with my project?
(2,889 Views)
Rich,
In the Create Distribution Kit for CVi 6.0, there is a setting to install NI-Report Support (see attached image). If you select this option, CVI will include the NI-Reports ActiveX server in your installation. This should be all you need in order to use NI-Reports on the target machine.
Azucena
NI
(2,889 Views)
