LabWindows/CVI
how to return a safe array/variant from a CVI DLL to visual basic?
I am trying to return a safe array from a CVI Dll to visual basic. I can successfully call CVI functions from VB and return simple types like int , double etc but when I try to return a Safe Array then the "generate visual basic module" gives me error.
The line that give error in the header file to generate the visual basic module is
LPSAFEARRAY* getAmplitudes() ;
and the function where i generate the safe array is
CA_Array1DToSafeArray (Amplitudes, CAVT_DOUBLE, iterations, safeArray);
return safeArray;
(2,802 Views)
Try putting the safearray in a VARIANT with CA_VariantSetSafeArray and returning the VARIANT instead of the safearray. Something like:
VARIANT* getAmplitudes()
VARIANT vArray;
CA_VariantSetSafeArray (&vArray, CAVT_DOUBLE, safeArray);
return &vArray;
Best Regards,
Chris Matthews
(2,802 Views)
I tried doing that but the generate visual basic include option gives the following error
syntax error found '*' expecting ';'
I had included the following line
VARIANT* getPWArray(int dummy) ;
Then I included , i.e
#include
VARIANT* getPWArray(int dummy);
in that case it gives an error "invalid visual basic return type pointer"
Then I removed the "*" i.e
#include
VARIANT getPWArray(int dummy);
in that case it gives the error
invalid visual basic return type VARIANT.
seems like only simple types like int , char etc are allowed to be returned to VB.
thanks for your help!
(2,802 Views)
