LabWindows/CVI
linux compatibility, which functions are portable?
I've started on my very first CVI project and would appreciate some pointers regarding which functions are portable to Linux or not.
I understand that W32 API calls are taboo, that's a no-brainer but the NI guidelines are to program in pure "ANSI C".  What does this mean exactly?
Can i use Fmt and Scan functions and still expect theprogram to compile under windows?
I need VISA on Linux, so I'm assuming all VISA functions are portable?
 I'm a seasoned LabVIEW programmer but this is my first CVI project.
Shane.
Message 1 of 11
(4,262 Views)
I've been using CVI for Linux full time for almost 2 years, so I'll try to
answer a few questions for you...
> pointers
> regarding which functions are portable to Linux or not. I understand
> that W32
Correct...
That you can use the standard C library, currently a mix of C89 and C99.
Some functions such as vsnprintf are missing... but they are also missing
from the normal CVI. Basically the entire set of functions you find in the
FPs provided with CVI will work, with a few bugs and caveats.
> under
> windows? I need VISA on Linux, so I'm assuming all VISA functions are
> portable?  I'm a seasoned LabVIEW programmer but this is my
> first CVI
> project. Shane.
I don't know about Fmt and Scan but I expect they'll work.
Visa works, I've used it on one project; but the main reason I shifted
development to Linux is that I can write my own device drivers much more
simply than with Windows.
You can check the intalled libraries in the cvi linux directory.
Keep in mind that the compiler is actually gcc with some wrappers but that
is changeable.
Debugging is possible but not as convenient as with the CVI IDE.
I have some notes here: http://www.gdargaud.net/Hack/LabWindows.html#Linux
Guillaume Dargaud
Message 2 of 11
(4,246 Views)
Guilaume,
thanks for the info.  I just found out today that the RTE installs basically everything I'm using (Everything visible in a default installation of CVI).
I have installed no other libraries, so I suppose my program should be protable as-is?
Are there any specific conventions I need to adhere to to keep things portable?  What about DLLs, or shared libraries?  Can I create a shared library for Linux using the same source code for a Windows DLL if I use the DLLEXPORT macro?
Sorry for the noob questions, but I AM a n oob in this area.
Shane.
Message 3 of 11
(4,245 Views)
here you get a link about what you can do in CVI Linux: http://zone.ni.com/devzone/cda/tut/p/id/2823
In Linux, shared libraries are called "shared object" files and end in a ".so" extension. You can use the gcc compiler to create one.
Check out the following link:
http://www-106.ibm.com/developerworks/linux/library/l-dll.html?dwzone=linux
Or you will need to recompile your shared library in CVI Linux. Then you can call this shared library there.
Regards
DianaS
Message 4 of 11
(4,220 Views)
> Guilaume, thanks for the info.  I just found out today that the
> RTE
> installation of
> CVI). I have installed no other libraries, so I suppose my program
> should be
> protable as-is?
Yes, I find the portability one of the great advantages.
> portable?
Not particularly. I try to stick to ANSI C and standard CVI libraries. Some
of those libraries rely on Windows stuff and if you look in their code
you'll find lots of #ifdef _ni_linux_ to work around them. That's where the
missing functionalities or bugs are likely to be.
Keep in mind that the current RTE for Linux is 8.0, a full number behind the
Windows version, so some of the latest stuff may not work and you may not
even be aware of it (the RTE in Linux just ignores errors instead of
bringing a popup).
> for Linux
You can certainly create a .so with the same code as your dll code. It's
been a while since I last created libraries for Linux, but all you may have
to do is put some empty #define DLLEXPORT
Then create you prog with
cvicc -debug -rebuild -lmyownlib MyProject.prj
Guillaume Dargaud
Message 5 of 11
(4,219 Views)
@DianaS,  which functionality can I use with gcc?  I was just reading up on this and it seems I need to buy a specific CVI compiler for Linux but if it can work witrh gcc (I'm not using any UI stuff) then that's cheaper of course.....
@Guillaume, thanks for the info.  I think I have enough information to be able to proceed with less fear now 🙂
Shane
Message 6 of 11
(4,216 Views)
Hi Shane
if you order CVI for Linux http://sine.ni.com/nips/cds/view/p/lang/de/nid/203157 you have a lot of more functions and can easily develop a graphical user interface. Also you have included the libraries for our hardware (DAQmx, visa, gpib...)
Regards
DianaS
Message 7 of 11
(4,211 Views)
Diana,
if all I need is VISA and ANSI C, can I compile the program using gcc?
The VISA installation on Linux copies all the header files needed for VISA right?
Shane.
Message 8 of 11
(4,201 Views)
I don't know if this will work and we don't support it.
Regards
DianaS
Message 9 of 11
(4,197 Views)
Hi Diana,
The second part is clear (no support) but it's the first part which would interest me since you've mentioned it in an earlier post.
Shane.
Message 10 of 11
(4,195 Views)
