LabWindows/CVI
project closes after I run and close certain VIs
I am running LabVIEW 2009 9.0f3 and am running into a couple odd things, I wanted to check if anyone else has seen this.  If I open the project it will close after closing certain VIs after they are run.  If I have a second VI open the project will remain open upon closing the VI.  This does not happen with all of the VIs in the project, only a couple of them.  This will also not happen unless the VI is run.
If anyone has ran into this and figured out how to fix it, or just has some ideas. I apreciate the input.
John
(2,573 Views)
posted on the wrong board, please delete thread
(2,565 Views)
