LabWindows/CVI
quick question on renaming file after fclose()
ok..im trying to rename a text file after creating it, without exiting the program. i put a fclose(file) on a command button, and try to rename the file after pressing the button. If I try to rename it says file is in use. the weird thing is i made a smaller test program to see if I can rename the file after fclose() and it works fine. but I can't get it to work im my original program. i also used a fflush() before fclose, but no luck. Thanks for any help
(3,561 Views)
I have already found a similar error while trying to delete a file immediately after closing it but found no definitive answer in the forums: the whole discussion can be found here. It that case a double-disk with mirroring system was present which could introduce some more latency after CloseFile returns.
I ended up adding some Delay between CloseFile and DeleteFile, but maybe a more efficient solution could be to place a little loop that periodically triese to rename and exits only if no error is found.
(3,549 Views)
hmm...ok. dont know exactly why this worked, but I fixed it. I had a code like this in a cmd button
 if(out=fopen("result.txt", "r"))
    if(!(ConfirmPopup("WARNING", "r u sure u wanna overwrite result?(if not choose NO and rename file))")))
    return 0;
      GetCtrlVal(panelHandle, PANEL_RING,&temp);
     keithley_id="ASRL1::INSTR";
     keithley_id[4]=temp ;
     func=KE2700_VAL_FREQ;
 // printf("%c %c %d xx", keithley_id[4], temp, func);
 // getchar();
 out=fopen("result.txt", "a+");
most of the part was just a routine to test if a file exists. I noticed i was getting non fatal run time error for that, when the file didnt exist. after commenting it out and using fclose() I seem to be able to rename the file. any ideas what is going on here? I also tried to set the *out to NULL, but that didnt let me rename either.
(3,531 Views)
