04-27-2011 03:14 AM
I have been working with Labwindows CVI 2009 with no problem but after upgrading to 2010 version I have the following problem:
When i´m going to execute the unistaller, either from Windows Control Panel or directly from the uninst.exe icon, it doesn´t work. The PC thinks a few seconds and does nothing, and it happens with all the applications I build with Labwindows CVi 2010.
Asier
Solved! Go to Solution.
04-27-2011 08:52 AM
Hello -
Are you installing these distributions on a non-English operating system? If so, the first thing to try would be the workaround listed on this known issue.
The known issue only lists Italian OSs as the troublesome OS, but it could actually happen on many different non-English OSs. I will update the text accordingly the next time I update the known issues list.
NickB
04-27-2011 09:17 AM
Does anyone know if all non-English versions of Windows supply the option to switch to English as described in the workaround?
--Ian
04-27-2011 10:12 AM
Hello NickB,
That´s the solution. I have changed my OS clock to English (EEUU) and it works properly.+
Asier
