Linux Users
Error: 'Unable to View Properties' When Placing DAQ Assistant in Block Diagram
When placing the DAQ Assistant, it shows 'unable to view properties.' .
The low-level DAQ functions work fine. What do you think could be the cause?
My environment
-Ubuntu 22.04 LTS
-LabVIEW 2024Q1.
-ni-daqmx 2024Q1
 and as options, ni-daqmx-cdaq-firmware, ni-daqmx-labview-support and ni-daqmx-labview-2021-support.
(376 Views)
Hi @tetora27, I'm not sure if this is the reason you are seeing what you're seeing, but I'm not sure that you have the correct LabVIEW support package.
Check out this page: https://www.ni.com/docs/en-US/bundle/ni-platform-on-linux-desktop/page/supported-drivers-for-linux-d...
You can see the listed optional packages for DAQmx there, and there are a couple options for the LabVIEW support package for DAQmx. One of them is version-specific (looks like you used the version-specific one for LV2021) and one is version-agnostic. Bottom of that page describes differences in those package types, but long-story-short, you should only use the version-specific one if you are using that specific version of LabVIEW. For the most part, all the recent LV versions and driver versions are able to use the version-agnostic LV-support packages. In the case of DAQmx, that package is
ni-daqmx-labview-supportlib
I don't think it should hurt anything to have both LV support packages installed. But if you don't have the version-agnostic one installed and you're using LV2024, that would likely create issues with palettes and other editor issues.
(340 Views)
