Lookout
opc communications problem
When building a replacement SCADA computer, and moving over a working Lookout 6.0.2 (with updates) application, we have been unable to get opc communications working.
The Lookout alarm that we get for the opc is:  "OPC/OLE error (1): Couldn't create an OPC server object (65): Class is not licensed for use (80040112)".  We have an activated full integrator version of Lookout.  Does anyone have any advice on this problem?
(6,792 Views)
Which OPC Server object are you using?
Ryan Shi
(6,785 Views)
problem resolved.  apparently the error message indicated that the RSLinx was not properly activated. after proper activation, the error cleared and communications through opc was functional.
(6,762 Views)
