04-05-2016 11:00 AM
I am trying to use Find Systems.vi to find the CVS. One of the inputs is "Device Class". According to help, it "specifies the type of device for which you are searching. Common values are PXI and cRIO". What is the device class for CVS?
Spoiler Alert: "CVS" doesn't work!
04-05-2016 11:29 AM
"CVS" should be the correct device class, unless you are using a CVS-1451RT. In that case the device class is "IndustrialController." Using CVS as the device class seems to be working fine on my end.
What kind of CVS do you have and which versions of NI Software do you have installed? Can you see the CVS in MAX? If possible, can you tell if Find Systems can correctly locate non-CVS devices?
-Katie
