Machine Vision
Error -1074396077 (IMAQ Vision: Incompatible image type) after running IMAQ Mask
I am attempting to process color picture of pellet. I want to exclude any particle that touches the edges of the color images. I created mask from original image and used this mask on the original color image to retain only the color particles that don't touch the boundary. The error occured  when I ran the IMAQ Mask. The error message is “Error -1074396077 (IMAQ Vision:  Incompatible image type)”. How can I fix it ?
I have picture and program as attached.
(7,223 Views)
Hi
You get this error message when you pass an invalid image type to a function.
here you must pass an RGB mask . Use the IMAQ Cast Image function to do this
Hope this help
Regards
(7,220 Views)
Dear toto26
I can't find IMAQ Cast Image function. Pls. instruct more details
Thanks and regards,
(7,209 Views)
Hi XuanThuy,
The IMAQ Cast function is part of the Vision Development Module (VDM), under the Image Management Palette, as indicated by this document: http://zone.ni.com/reference/en-XX/help/370281P-01/imaqvision/imaq_cast_image/. If you can't locate it and you indeed have the VDM, there may be an issue with the installation of this module. A similar issue has been encountered and resolved in this forum post: http://forums.ni.com/t5/Machine-Vision/can-t-find-IMAQ-cast-image-vi/td-p/340157. What version of the vision software are you using?
(7,179 Views)
Dear Joseph-S,
I will find and try it. I use Labview 2011.
(7,173 Views)
Dear Joseph-S and toto26,
I tried use IMAQ Cast but IMAQ Cast can't convert U8 image mask to RGB mask. I have program as attached. May you help me ?
(7,149 Views)
Hi were you able to solve your problem. I am using LV 2010, Could you provided your color sortor vi code in 2010? I am having same error in IMAQ mask. I have full development module running on my computer. Thanks,
(6,936 Views)
