Machine Vision
Find end points of line
Hi All,
I have a binary image which has a single line obtained after some processing done on a grayscale input image as seen in the attached image. How can I find the end points of this line?
Regards
Aveo
Message 1 of 11
(4,682 Views)
You can use edge detection where you can get end point of a line
One more method, you can use IMAGE to Array where you can get array of pixels you can filter using some operations with offset above certain value to get the line pixel and find the end points of a line from an array.
Message 2 of 11
(4,661 Views)
The line can be oriented in any direction, not just the horizontal plane. As far as I remember, the first approach to detect edge might not work because of the search direction parameter. Am I right?
The second solution is good, however with increase in image size, the number of iterations will increase in order to check for end points.
Another method that I have been working on is to find the max feret start XY and end XY using IMAQ particle analysis. This takes care of the rotation of the line too. I have been testing it with my image sets. So far it has worked. 😉 I will update if it fails.
Message 3 of 11
(4,659 Views)
Curious Why does the Bounding rectangle doesn't help to give the end points?
uday
Message 4 of 11
(4,655 Views)
Interesting thought!  Yes we can use bounding box to get the point coordinates.
However suppose we have two lines as shown in the attached image. Both will give the same bounding box. It will be difficult to interpret whether the line start point is at the top left corner or bottom left corner.
One way around would be to use first pixel XY along with bounding rectangle to find the points.
Message 5 of 11
(4,648 Views)
In the initial post i had an impression that it is single line hence my suggestion was to use Bounding Box.
-If there are multiple lines like in the latest, it doesn't work becasue particle analysis works on binary particle and here it is single particle since there is no disconnection hence it gives as single bounding box.
-You can try shape detection(grayscale not binary) for lines. Still the problem is in your image it would be 8 lines with edge detection.
-Could there be more lines in next posts? I'm out of ideas unless full problem is known 🙂
uday
Message 6 of 11
(4,628 Views)
Well actually, I think I was not clear enough. Pardon me.
I will always be having only a single line per image. What I wanted to show using the previous image is that- assume there are two images of same height and width and each image had one of the lines in them. In first image the line starts at top right corner and ends at bottom left corner(lets call this line 1). In second image the line starts at top left corner and ends at bottom right corner(lets call this line 2). Now when you apply particle analysis to each image, the bounding box of both these lines will be same if
1) Both the lines are of same length
2) The X coordinate of end point of line 1 is same as X coordinate of start point of line 2
3) The X coordinate of start point of line 1 is same as X coordinate of end point of line 2.
So in this case I cannot figure out whether the line starts at top right or top left.
This is a boundary condition that will fail if we use only bounding box. Now instead if I also compute the start pixel XY along with bounding box then it can be solved.
Regards
Aveo
Message 7 of 11
(4,623 Views)
Did you check First Pixel X and First Pixel Y measurements?
uday
Message 8 of 11
(4,617 Views)
I was referring the first pixel XY as start pixel XY until now 😛
Regards
Aveo
Message 9 of 11
(4,611 Views)
you can use this vi and serach for max and min inside the  image for colum and row
 in this case you have 4 number that relate to end of the line x and y
Message 10 of 11
(4,590 Views)
