Machine Vision
NI 1772 Smart Camera not connecting or showing up / connectivity issues
I am having an issue with one of my NI 1772 Smart Cameras. We have about 8 of them, but for some reason, one will not connect. I open National Instruments Vision Builder AI software, connect the camera via ethernet, and the green light comes on on the camera. However, when I hit refresh in the software, the light does not blink or do anything, and therefore, the camera does not show up. I only have this issue with one camera. The rest show up when I hit refresh. They are not networked, I connect to each one individually.
Is there a way to do a factory reset on these cameras? Is there a default IP address assigned to these that I could try to type in and manually add the camera? Did it die?
Any input would be greatly appreciated.
(3,117 Views)
Hello crave123
The 177x Smart Cameras should give user access to a console out feature which shows the current IP address of the target.
http://digital.ni.com/public.nsf/allkb/3569E73B8B865C0986257B59005FA2AF?OpenDocument
In this document there are a good number of steps that we can try to see the current IP address, reset the IP address (using a DIP switch control accessory which you may or may not still have), and a few other steps that might be helpful.
Please take a look at this document and post back here if you have any trouble!
Have a great week!
John H.
Applications Engineering
(3,068 Views)
This was very helpful. I was able to connect the camera to a monitor and see that I had a fatal crash. I forget the code, but I was unable to reset the camera here manually, so I had to send it back to NI. Thanks again.
(3,045 Views)
Hello Crave123,
Thanks for the update. We are always happy to help!
John H.
(3,036 Views)
