I need to show the curves found by the "IMAQ Learn Geometric Pattern 2" and/or "IMAQ Match Geometric Pattern 2" VIs. This is to give feedback to the operator when setting up the curve parameters.
Using the Vision Template Editor is no option as it is too complicated for the user.
Someone recommended to use the "IMAQ Extract Contour" VI as it returns the found curves. But I am not sure if it internally works the same way as the geometric matching VIs...
Any ideas?
Ingo
