12-04-2020 12:23 AM
I am reading 4 Balser aca 2500 14gm cameras with the parameters as shown below.
I have read the camera but it has some problems when I grab the image. It appeared black lines on the image, like it lost data transmission, I also split the bandwidth of 4 cameras evenly. I don't know if anyone has this situation like me, can help me give some advice to fix it.
Thank all.
12-04-2020 02:08 AM
This behaviour means you are losing packets. You can check this by monitoring packet related status information :
When you say you split the bandwidth, how did you proceed ? Because if you just decreased frame rate, that will not be enough as the peak data rate is not changed.
I would recommend :
Sami
12-04-2020 02:20 AM
12-04-2020 04:25 AM
I would strongly suggest you enable jumbo frames to use much bigger packet size (8 or 9k). If your ethernet adapter does not have such a feature, change to another one and also reduce the desiredpeakbandwidth to lower value (150, 200 ?).
Sami
